Help! My Save Drawing As Dialog Box is Missing!
I hope someone with a similar experience can help me. You see, my Save Drawing As dialog box is missing, and I can't seem to find it.
Here's the situation. Previously, when I want to save my AutoCAD work, I click on File, then Save, or File, then Save As ... and a dialog box appears where I see which folder I am working in, and type in a filename to save my work.
Now, whenever I click on File, then Save, the dialog box doesn't appear. Instead, Command Line kicks in. It has text like:
Command:_saveas
Current file format:AutoCAD 2000 Drawing
Enter file format: [R13(LT95)/RT14(LT98/LT97)/2000/Standard/DXF/Template] <2000>:
But No Dialog Box!It does the job ok, I can still save my files, but it is tedious. It really gets hairy when I try to open a file, because then, I have to type out the whole file name, and I am one of the firm believers of long file names!
I am thinking I may have "re-set" some settings for AutoCAD to do this, but I just can't figure out what. Help.
I hope you all get a gist of my problem and can provide me some advice. Thanks in advance.
Command:_saveas
RE: Help! My Save Drawing As Dialog Box is Missing!
Hope this helps.
I love these forums, and how sharing what you know can really make a difference for someone else.
Have a great day!
