Guardrail Transition - Cable Rail to Thrie Beam
I am looking to replace Cable Guardrail Along a local roadway that is adjacent to the bridge with Aluminum Rail as this state does not accept Cable Guardrail as acceptable.
We do not plan to replace miles and miles of this so we are looking for a viable solution to transition the cable rail to the aluminum rail?
If anyone has ever run into this before, suggestions would be grateful.
RE: Guardrail Transition - Cable Rail to Thrie Beam
Check with http://mcmastercarr.com to see if they have a "line" of aluminum rails. Be sure to pick a rail that meets hiway standards for collision loads.
