Surfcam Post forCentroid m-39 controller??
Does anyone know of a post inside surfcam that will work with the controller mentioned above?? It would really help!!
RE: Surfcam Post forCentroid m-39 controller??
I don’t see any Centroid controls listed in the post wizard.  Check with the Centroid manufacturer and they may suggest a post that is similar such as Fanuc that could be edited.  Surfcam’s post are easy to edit.  Your Surfcam dealer should be able to help set one up that will work.
I have one for centroid it works, how can i send it to you?...regards to all,from mexico
