Formula for Elbow under Internal Pressure?
What is the equation to calculate the required thickness of a 90 degree elbow under internal pressure?
-Christine
-Christine
Formula for Elbow under Internal Pressure?Formula for Elbow under Internal Pressure?(OP)
Thanks, -Christine Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Formula for Elbow under Internal Pressure?
See API-579 A.5.5 (pgs A-31, 32) and Fig A.14 (pg A-53). ASME B16.9 part 2.2 refers to B16.49 for bends. I don't have B16.49 so I don't know if it provides the same formulas as API-579.
One problem is that many manufacturers opt out of the tmin calc's by proof testing.
See also thread378-122201.
jt
From B31.3, 2004, paragraph 304.2.1:
Based upon the classic torus equation
The minimum required thicknes of a bend after bending in its finished form is calculated by:
t-min = (PD) / 2[(SEW/I) + PY]
where at the intrados (inside bend radius)
I = [4(R1/D) - 1] / [4(R1/D) - 2]
and at the extrados (outside the bend radius):
I = [4(R1/D) + 1] / [4(R1/D) + 2]
and at the sidewall of the bend
I = 1.0
and;
Y is the bend angle (e.g., 90 degrees)
R1 is the centerline radius
D is the pipe ouside diameter
P is the internal pressure
You must decide what corrosion allowance is needed and of course you may want to add thickness for groving, erosion, threading, etc.
If you are using a standard B16.9 welding elbow you only need to specify the schedule of the matching pipe.
Regards, John.
Because it is not a straight pipe under internal pressure! If you have access to a FEA package, model an elbow and apply internal pressure. You'll see a nice distribution of stresses, not a consistent pr/t stress.
jt
David was not totally wrong. According to UG-44, if the elbow was made to meet ASME B16.9 or B16.11, it could be calculated as a straight seamless pipe.
Depending on how you interpret "calculate" I might agree with you: If by "calculate" you mean "determine a pipe schedule for straight pipe and order an elbow of the same schedule" then I'll agree. If you mean "determine the required wall thickness of an elbow" then I'll disagree. This would be true for either VIII-1 or B31 applications.
This is generally not an issue which comes up in new construction, but in evaluating the fitness for service of existing piping (and less frequently, vessel nozzles).
jt
The Y in the formula is not the bend angle but a material/temperature depending coefficient to be taken from table 304.1.1
I mean the first one.
