We are building a new factory
and I am an electric engineer there responsible about the lighting and fittings now.
then I am supposed to install the machinery later and I want to make sure that every electrical component is installed safely. So any body can help with detailed advice or give any site or papers concerning this.
thanks. K.
thanks. K.
RE: We are building a new factory
i am surprised that you are not familiar with machinery installation and electrical load design and calculation considering that you are an electrical engineer.
If you are a fresh graduate EE, i would suggest to get help from a consultant or a qualified electrical contractor..normally as an EE...new plant/factory installation is one the most exciting experience in electrical engineering and i am sure most of the reader will agree..
good luck..
dydt..
A.Rash BScEE & PE
a_rash@bigfoot.com
Reference Data for Electrical Engineers
by Donald Fink...
good book...tons of information on
almost everything..from foundation..
machine guarding...etc..
good luck
dydt
standard handbook for electrical engineers
by donald fink
regards
dydt
http://www.nfpa.org
http://www.nfpa.org/codesonline/
(for NFC on line master index)
for safety related codes and standards
