spec for "clay dam" or other groundwater stop in trench
I'm designing sewer and drain pipe trenching and know there are wetlands and/or seawater nearby and the trenches will be in groundwater. I'm aware that "clay dams" have been used to prevent transportation of groundwater in trenches. I've also heard I won't be able to obtain clay. I'm looking for specifications and/or drawing details of a way to stop the flow of groundwater in a trench that will contain crushed stone up to 1 foot above the pipe. The soils in this area are also sandy and readily allow groundwater flow. Thanks.
RE: spec for "clay dam" or other groundwater stop in trench
http
I ain't never seen a hearse with a luggage rack.-GS
Wellpoints are often though to be limited to use when they can surround the excavation. However they work quite nicely when installed on one side of, and parallel to a "linear" excavation, such as a pipe trench - they don't even have to be too close; placement 10' or more from the trench is typical.
www.SlideRuleEra.net
