motor speed and power for thread check
i'm looking to implement a new way to check tapped holes in our automotive parts produced off the machining lines. i have a good idea about how to go about this, but am not sure on what size motor to use. this motor will be powering 8 spindles that need to all spin at the same speed throughout a tapped hole. Two different speeds will need to be used on each spindle: one for initial thread(to prevent cross-threading) and the other to travel the rest of the way through the hole. I've calculated my approximate speeds to be 30 and 125 rpm. A frequency drive and PLC will control the speeds and timing. Is there a three phase motor that will work for this application?
RE: motor speed and power for thread check
TygerDawg
Take a look at this device based on Eddy Current that works quite well and may do all you need.
http://www.ndttechinc.com/qweb/site/index.htm
