parallel plane thru a "keypoint"
I was running a S-E tutorial, and a mirror step called for creatng a parallel plane thru a key point, and that I should select the keypoint from a keypoint icon drop-down list on the ribbon-bar right next to the drop-down for selecting planes ("...select parallel plane").
This was in the sheet-metal tutorial, and the step was mirroring the tab with the hole in it.
There was no keypoint icon next to the mirror-type drop-down, so clearly I couldn't select the midpoint keypoint. This was a feature I was really interested in for other constructions I'm doing (I try to run a tutorial a day...), but I couldn't find it where it was supposed to appear according to the tutorial.
Any suggestions? Did I miss a step?
S-E v17
Tks-
C. Fee
S-E v17
Tks-
C. Fee
RE: parallel plane thru a "keypoint"
When you are in the mirror copy feature command :
1/ select the features and accept
1/ Select 'parallel plane' in the drop list
2/ click a plane you want to be parallel to
3/ some more icons appear. You should be able to pick your mid-point. If not, click on the icon directly to the right of the plane droplist (red dots on ble geometries) to specify the type of point to mid-point.
HTH
Fred
Thanks for your reply. I'll check it out and get back to you.
C.F.
