SOLIDWORKS AND HULL DESIGN
HOW SHOULD I BUILD A BOAT HULL AND FRAMES USING SOLIDWORKS?
ARE THERE ANY GOOD BOOKS THAT APPROACHES SOLIDWORKS FROM A MARINE PERSPECTIVE?
RE: SOLIDWORKS AND HULL DESIGN
SEAARK,
Most likely you are going to have to use the loft feature for the hull shape. As far as creating the beam structure I would look into creating weldment profiles of standard 2x4's and such. Then use the weldment features to create the framing. I have not seen any books on marine design with Solidworks. I think you are just going to have to start using it and find out what works best for you.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
How familiar are you with SolidWorks?  You'll need to get into some advanced shaping (lofts and sweeps, as jksolid mentioned) and will need to have a good understanding of such capacity for SW to do so.  You may even want to look into third-party software, depending on the accuracy needed.
Some things to check:
http://www.baren-boym.com/
    Check out ShapeWorks under the SolidWorks tools tab
http://www.productdesignforums.com/index.php?showtopic=230
    Great tutorial on surfacing with control
http://www.dimontegroup.com/Tutorials.htm
    Excellent tutorial by Ed Eaton on "swoopy stuff"
    (although I'm not able to connect to the site right now)
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
