calculating pressure drop in a nozle.
hallow everyone,
do any one have an idea how i can calculate or estimate pressure drop of water flow in a full cone nozle sprayer outlet of a wet cooling tower?Any helpful fomular will be appreciated.
RE: calculating pressure drop in a nozle.
Good luck,
Latexman
Good luck,
Latexman
Nozzle manufacturers rate their nozzle flow characteristics basis the available pressure drop in a system. I can't estimate without seeing your system, but other cooling towers I have seen usually have a delta pressure of 15 to 30 psi.
