VB programming function name help ?
Can anybody tell me the correct programming function name that allows me to make a "cutom property" name in SW, lets take for example I have a custom property name called "PLNOTE" i want my macro to add PLNOTE to every drawing I open up, this after I press the play button on my macro toolbar, and for the Type I want Text String, and for the value I want a "-" dash for now. I thought Property Let, Property Get, and Property Set where the right programming functions but I have a bad feeling I'm barking up the wrong tree using these functions, I've tried to use help on custom properties I didn't get anywhere, can anyone help me?
Printed Circuit Board Designer
Salt Lake City, Utah
Stangs rule!
RE: VB programming function name help ?
The commands you want are ModelDoc2::AddCustomInfo3 and ModelDoc2::CustomInfo2. These require a ModelDoc2 object st to your document of interest. Keep in mind that AddCustomInfo3 does not change or overwrite existing properties.
There is a "Copy Custom Info" macro at <http://www.esoxrepublic.com/freeware/> that you may dissect and use, but not plagiarize.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Thanks for you help on AddCustomInfo, the program works great ! I have the program delete all Custom Properties and VB creates the new one, you save me a lot of time. I really didn't feel like entering new properties in a hundred drawings.
Stangs rule!
