Steel Angle Iron to Concrete Achoring
I am going to install a cement test pad for equipment which will have access troughs formed in. I will be using 1-1/4" carbon steel angle iron to use as an edge and am looking for the proper way or item that can be used to anchor the corner angle into the cement when it is poured, such as a "J" bolt or "L" bolt. Are there specific types that are preferred and what would be an average spacing between these anchors. Thanks
RE: Steel Angle Iron to Concrete Achoring
