impedance matching
impedance matching
hi,
I´m working with some inductive loop antennas for RFID (i.e. no propagation antennas, only magnetic field coupling). The antennas are tuned to resonate at 13.56 MHz and have an impedance of 50 ohm.
Now I need to investigate the effect of placing two antennas close to each other, and were planning on connecting one of the antenas directly to a signal generator.
Will this work or do I need further impedance matching / use of baluns etc.
any help is appreciated.
regards
doneirik
regards
doneirik
RE: impedance matching
For electrically small antennas, usually they don't affect each other much due to their inefficiencies.
That doesn't answer your question for these tiny magnetic antennas, I wish I had the answer.
One thing to do is measure S21 from one antenna to another, although the cable you attach to these small antennas will likely change their properties (a common low frequency headache). If the coupling is really low (-30 dB), then they really won't affect each other.
kch
To VE1BLL: Well, It´s two antennas, no transformer.
The antennas I work with are 2 - 20 cm in diameter, which is only a fraction of the wavelength at 13.56 MHz (3.53m)
If the signal generator has a different output than 50 ohm, do I still have to construct a matching circuit?
And do the presence of another antenna always change the resonance frequency?
The reason I want to test this is with a very basic megnetic field simulation program I saw that placing two loop antennas close to each other with reversed polarity will yield a stronger magnetic field. However, with the simulator I couldn´t change the frequency (maybe it showed only a static situation) Does this sound reasonalbe, or would it be a waste of time even to test?
best regards
doneirik
Try monitoring the current in the first while shorting out the second. If the short propagates back to the source, then you can't pretend that it's not a transformer.
About the effect I was hoping for:
If I place two loop antennas close together (i.e. 2 50x50mm antennas about 5 - 10 cm apart) with reversed polarity, I was hoping that the effect of the coupling would be that the magnetic field would be "stable" at a longer distance from the antennas before it starts to fall off with 60dB per decade. In practice, with my RFID application this would yield a longer operating range.
doneirik
