.tst file and mapkey...WF
If someone could run the (Verify Instance) in the family table editor ...
doesn't have to me more than a few inst. and post a copy of the .tst file it creates .. will be in the current work dir.. that is if WF still creates one
Also if you record mapkey that is used to replace a generic model with one of the instances in drawing mode and post that one mapkey also...... you can pick any instance.... I really would appreciate it
also let me know what vers. WF you're using... I need to compare this to r2001
Emailed to me would be better at least the mapkey the tst file I just need to see if it the same format as r2001
not sure how email is done here
RE: .tst file and mapkey...WF
Forgot to mention that the tst file is a text file and can be opened with notepad
got em ...thanks
Is this related to automating drawing / dxf export of family table instances?  Would like to know, for future reference, if you get it working.
Oh I got it working in R2001...up 625 instances-10mins.
you got to be the same jeff4136 at a couple of other places
did you get my email??
