History of surface edge
Hi folks,
I have tne edge of a surface, which used to meet up with the edges of several other surfaces. I erased those, but now when I use the extract function to get a boundary curve from the original long surface, it gives me short curves where the smaller surfaces used to be. But I want one long boundary curve.
Does this make sense? How do I get the system to forget about the old shorter surfaces, so I can get a long boundary curve?
RE: History of surface edge
Can you post a specific image of your surface, and the adjacent surfaces?
Check out CATBlog!
Check out CATBlog!
