ac motor control
ac motor control
does anybody know if a single phase 115 vac motor, running at around 1700 rpm come to a dead stop if the power is switched off? by the way, the motor is driving a conveyor and the speed of the conveyor is being reduced first by a 30:1 gear box.
The idea is to start/stop the conveyor using a programmable relay.
Thanks.
Thanks.
RE: ac motor control
You left out an operative in between "rpm" and "come". Should? would? could? will? must? might? can? wants to? better not or I'll tell your father when he gets home?
In general though, the coast-to-stop time is dependant upon the load, not the motor. High inertia combined with low friction would mean a long coast time, low inertia with high friction would mean a very short coast time. Any combination variables of those two load components will result in an infinately variable outcome. In other words, no way to tell with the information you provided.
That said, conveyors are typically low inertia high friction, and combined with a 30:1 gear reduction, it is likely that it will stop quickly. But is the conveyor load going down hill? Is there a flywheel or dancer on it that has enough mass to keep it going? Is the gear reduction going the other way (I can't imagine a conveyor pulley running at 51,000rpm, but hey, who knows)?
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more."
Nikola Tesla
English is not so easy for us foreigners...
Gunnar Englund
www.gke.org
