issued with Catia V
issued with Catia V
issued with Catia V
I have CatiaV5 R14 (HD 2) is already installed & was trying to install Service Pack (SP4)& Hot fix.
I received 7 volume of Service Pack from IBM & was trying to install then I am getting error as below:
  "There is no need to install service pack 4 in
   C:/Program files/Dassault Systems/B14"
1. Does the error mean that I already have Service Pack installed?
2. Do i need to install all 7 Volume?
3. How do I know that service pack & Hot fix is installed
   or not?
4. How do i uninstall only Service Pack & Hotfix, if
   required?
Thanking you in advance,
RE: issued with Catia V
As for the service packs, you should only need to install SP8 (assuming R14 is already installed).  SPs are cumulative.
For the HotFix, it depends on the HF.  I suggest you contact IBM or whoever gave you the HotFix.
uninstall hotfixes the same way you uninstall any other piece of software - Control Panel, Add/Remove software.
That is also how you know if they are installed.
Check out CATBlog!
