Temperature measurement inside a microwave
I need to measure temperatures of about 800 degrees Celsius inside a microwave. Anybody knows what tipe to sensor could I use?
RE: Temperature measurement inside a microwave
An alternate is a fiberoptically coupled infrared pyrometer
TTFN
kch
h
The OP needs to post more information about object or material is being heated, how often the measurements need to be performed, allowable latency, is heating allowed to stop temporarily, etc.
TTFN
I personally don't have enough expertise to design a radiometer for this short a workign distance, nor do I think the OP has that experience. I also don't think that calibrating such a device is a trivial matter.
If you're offering to do the design and calibration, then by all means...
TTFN
Will
http://www.luxtron.com/pdf/m600.pdf
TTFN
I know that an MRI machine at the hospital can do that accurately.
kch
