Who can suggest suibable titanium pipe and flange materials
Currently I have to make a small spool of titanium to connect a titanium pump to plastic lined pipe system (for brine fluid). I am wondering what pipe and flange material standards I should use in ASME/ASTM system?
thanks
thanks
RE: Who can suggest suibable titanium pipe and flange materials
NozzleTwister
Houston, Texas
Datasheet T01
Steve Jones
http://www.pdo.co.om/pdo/
As to grade selection, it depends entirely on the service. Commercially pure titanium (gr2) is the most commonly used. Grades 1-4 are all commercially pure titanium with varying oxygen/nitrogen contents. "Brine fluid" isn't descriptive enough to help much in selecting a grade. Have a look at www.timet.com for some useful information on titanium.
Any particular reason you just don't have a "plastic-lined" spool made up to mate with your pump? Probably cheaper, especially if your titanium spool will require welding...
