JLink Samples Installation Problem
I'm having trouble running the JLink samples.
I'm running wildfire 2.0 on windows xp pro.
I've run the following command at the c: prompt
set classpath=.;C:\Program Files\proeWildfire 2.0\text\java\pfc.jar;%classpath%
without any messages
When I try to run javac *.java from the samples folder it tells me that javac is not recognised as an internal or external command.
When I try to run C:\Program Files\Java\jdk1.5.0_03\bin\javac *.java i get the message 'c:\program' is not recognised as an internal or external command.
When I go to the jdk1.5.0_03\bin folder and run javac c:\program files\proewildfire 2.0\jlink\jlink_appls\install_test\*.java I get the message 'invalid flag: C:program '.
What is going on?
Why won't it work?
What is going on?
Why won't it work?
RE: JLink Samples Installation Problem
From the sounds of it, J-Link thinks the location string ends with the space.
I managed to make the demos work at our old office, and all of our Pro/E Installations were in folders like the one I stated above. We never really got into our own J-Link customization due to time constraints, though.
I believe you also need to set a CLASSPATH environment variable that points it to the Java Runtime Environment as well. Unfortunately I don't have any documentation any more so I am strictly going on memory.
The java files have now compiled but I still get an 'Installation failed' message?
Does anyone know how I check to see if I have a licence to run JLink?
1. Right click on your project and click properties.
2. Click the 'Libraries' category.
3. Click the 'Add JAR/Folder'.
4. Browse to the pfc.jar (c:\ptc\pro\text\java\pfc.jar) and add it.
5. Rebuild and the pfcSession should be defined.
