Where is my "publish edrawing" menu line?
I am using 2005 sp3.0.  And I used to save edrawings by file-Publish edrawing.  Since I went to 2005, I dont have it.  I used to have it in 2003.  And my neighbor who is on 2005 sp1 also has it.  How can I get it back or is it not available with sp3?
RE: Where is my "publish edrawing" menu line?
As long as you have eDrawings Pro installed on your machine, that menu item should be available.  Try doing a repair on eDrawings Pro if you know it is already installed.
Have you checked whether that menu option is set to show in Files > Customize Menu?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Tools\Add-ins\Edrawings - is that add-in on? If not then nothing will show up.
Did you upgrade from SW03 to SW05? - if so, follow the uninstall and reinstall FAQ from this forum. You should never upgrade from one version to the next and especially if you skip a major version.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
That was it Scott.  The part about addins.  Yes I did go direct from 2003 to 2005, but still use 2003 occasionally.
Thanks Scott.
