What's the difference between transmissivity and K?
Let me start out with a personal statement.  I have prided myself in having been able to get through the subject of geology knowing little to none about the field of hydrology.  Now that I am breaking out my old books, I am finding out why.  I believe it is an intrinsically confused subject, with redundant terms and misplaced concepts galore.  Nonetheless, it is a science I now need to know.
I am curious about the practical aspect of transmissivity.  I noticed that the units used, GPD/ft are very close to hydraulic conductivity, GPD/ft*ft.  Am I right in assuming that transmissivity is just the horizontal component of hydraulic conductivity, for water moving through an aquifer?
Thanks.
RE: What's the difference between transmissivity and K?
Hi Dirt -
You had to say "practical aspect", didn't you...
Horizontal hydraulic conductivity is essentially the coefficient of permeability of a medium, and it quantifies the capacity of the medium to transmit water.  Units are that of speed (length/time).  The higher the number, the more permeable the medium is.  With some caveats, it's essentially the rate of flow of water through a cross-section of one square foot of the aquifer medium, under a unit hydrualic gradient.
Transmissivity may seem less a nebulous concept if you remember the following relationship, keeping units constant:
T=kb
where T= transmissivity
      k= horizontal hydraulic conductivity
      b= thickness of the aquifer
An example is helpful...
An aquifer with a horizontal hydraulic conductivity of 10 feet/day that has a saturated thickness of 25 feet would have a transmissivity of 250 feet^2/day.
or...
Same aquifer would have a transmissivity of 1870 gpd/ft.
"Gallons per day per foot" is also a typical unit for transmissivity.  To convert between these two units of transmissivity, just remember a cubic foot contains 7.481 gallons, and divide or multiply by 7.481 as the case may be.
Thank you.  These concepts seem less nebulous to me.  I am eternally grateful for competent persons like yourself in the world.  I was going about nuts!
I have to admit, those units continue to be cloud-worthy to me.  It seems much easier to consider movement in terms of length/time than [volume/time]/length.
Thank you again!  Mental clarity is at a premium these days...
