MA Structural Engineer wants to work to New york
I've worked as a structural Engineer in a small design office in Massachusetts for five years. I’ve been here since I graduated college. All of my projects are in Massachusetts and I don't have any experience with  New York building standards/codes. I don't even know what code they use? I think they may even have their own code like Massachusetts does.
Does anyone know what code is used in New York, and what difficulties I could anticipate (or prepare for) prior to applying for a job there.
All help is greatly appreciated
Tweedledee
RE: MA Structural Engineer wants to work to New york
I'm sure you've already anticipated the "Yankee Fan" difficulty...
Best place I can think of to ask/answer your query.
http://www.op.nysed.gov/pe.htm
new york uses modified version of 2000 IBC. it should not be difficult to get a job in ny. I do work in MA and NY. the code are similiar, Mass being based on the old BOCA code. thay have changed some things between the two ( mainly wind and seismic) but nothing that a structural engineer with 5 years experiance should not be able to pick up quickly
