installing V5R15/MULTICAx
I installed V5R15 P2 and it seems to work fine. I just installed it from the CDs called CATIA P2 Solutions. However, there's another set of CDs, called CATIA/ENOVIA MULTICAx Products. I put the Windows version in the CD drive and it apparently started installing V5R15. Should I have started the installation with this CD instead of V5R15 P2 Solution?
What's the difference?
Thanks.
Thanks.
RE: installing V5R15/MULTICAx
For the information on MULTICAx, go here
Hope that helps.
Check out CATBlog!
I haven't seen signs of it yet.
