Immersion Marshall Stability
In Canada, we used the Immersion Marshall test for asphalt pavement in airport projects. Also, in road usage. However, it is not a standard test. Is there similar test in the US, or the rest of the world ?
The test is comparison between the regular Marshall test, with the test with 24 hour immersion of the briquettes in 140F water bath (60C). Usually, you make 2 sets of 4 briquettes each. One set to be tested regularly, the others to be immersed first . We usually require a minimum 75% retained in Stability.
RE: Immersion Marshall Stability
