Webinar on Heat Transfer Analysis using FEA
I recently presented a web seminar on heat transfer analysis using FEA. Several of the examples used are based on IR applications. A link to register to see it, which can be done at your choice of time from the recorded presentation, is available on the home page of Kleinfeld Technical Services, Inc.
I look forward to your comments.
Jack
Jack M. Kleinfeld, P.E.  Kleinfeld Technical Services, Inc.
Infrared Thermography, Finite Element Analysis, Process Engineering
www.KleinfeldTechnical.com
