Extrude Part to Stop at Other Part
Hi Ya All,
Just found this site and you all seem to know what you are doing with inventor, so I have a question for you.  I want to be able to extrude a part and have the extrusion stop on a complex/curved face of another part OR failing that:- I would like to subtract one solid from another, just like I'm used to doing in MDT or even 3D.  Can anyone help me with this?
RE: Extrude Part to Stop at Other Part
Snapey...Assuming that the document constrains allow it, the easiest way to extrude a sketch to a surface is to click on the menu button that displays "distance" in the extents section of the extrude dialogue window. There should be an option "to". Select "to" and then select the face that you wish to extrude to. The sketch should now extend to the surface selected.
If you wish to subtract a solid from a solid, select cut instead of join.
The three buttons in the middle of the extrude dialogue box control the extrusion output. The top one joins the extrusions assuming there is more than one. The middle one cuts the current extrusion from the solid through which the extrusion will pass. The bottom button...well its easier if you try it. Its difficult to explain what it does.
