AB Activation
AB Activation
AB Activation
Guys,
Just got a shiny new laptop that came without a floppy drive….anyone have any ideas how I can get the AB activation file onto the new machine?
Would a USB key work or do I need to get a floppy drive?
Cheers
RE: AB Activation
Hi
As I understand it, it probably is possible to use a USB key but it is also probably in breach of the license agreement.
plcman
www.wolfelectrical.co.uk
RE: AB Activation
You can move the activations to a network drive and use them there.  In fact if you use a thumb drive you have to map it so it looks like a network drive.
You can get activation help from AB tech support.
Hope this helps.
RE: AB Activation
Why not buy a USB floppy drive for around £20?
RE: AB Activation
just had the same problem. You can use a memory stick on a computer with a floppy. move the activation file to the memory stick and then move it to your new laptop.
RE: AB Activation
sorry, should have let you know ages ago....
you can use a flash drive but you need to get a couple of little programs from the AB website
RE: AB Activation
USB floppy works just fine!
