RUSTY FITTING/ACID PICKLING /ANTOX 71 E
As I know this product  (ANTOX 71 E ) is being used for   remove  oxidation  from weld seams
I have  o lot of rusty  Stainles steel fitting and I have no chance  them  put in acid bath for surface treatment
I just wanna know is it  use  remove rust from directly pipe or fitting surface
if your answer is yes  how can be apply ?
regards....
RE: RUSTY FITTING/ACID PICKLING /ANTOX 71 E
This product is a mixture of HF and HNO3. It will dissolve oxide on stainless. However, if you have rust, there is a good chance what you have is not an oxide of stainless but some iron oxide from another source. Why not try something less severe like HNO3 alone first? Then you don't have the HF danger.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
I would suggest citric acid or phosphoric acid first.  They would remove surface rust.  Then you can see what the surface really looks like.
If it is already heavily pitted you should mechanicaly polish it and then reclean it with acid.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
