FiberGlass Epoxy Resin for a headlight shroud
Ok, so this might be a dumb question, but I have a set of custom foglights, they are projectors retrofitted into reflector housint, I need to make a custom shroud for them and was wondering if I could do it using epoxy resin, will it stand up to the heat of a 55W light bulb?
RE: FiberGlass Epoxy Resin for a headlight shroud
