Print To PNG
Print To PNG
I oftenly print my drawings to PNG image format and find it fair easy to use. Obtained images could be extremely big (pixels x pixels), but still of very small size (kbytes).
My problem is that I cannot set image resolution. In the "Printer Configuration" there is field named "Res.", but it is fixed to value 100 DPI and cannot be changed.
I know that i can change resolution somewhere else, but the result wouldn't be the same (linewidths differ). Results I get always have linewidths much thinner then I defined in Layer configuration (after scalinig obtained image).
Anyone knows why is this option disabled? How to enable it?
Any other suggestion?
Thanks in advance
Thanks in advance
RE: Print To PNG
http
"Everybody is ignorant, only on different subjects." — Will Rogers
