Transformer Noise
Transformer Noise
Transformer Noise
Hi There :
Actually I've a Problem into knewing the reason of mading transformer made low noise espicially when a speciall load ( Electrical Heater ) is operated connected to its secondrey
RE: Transformer Noise
I would guess the resistive load of the electric heater is sufficient to cause the transformer to humm.
There are several reasons that a transformer will humm,
1) loose laminations in the core
2) loose windings or winding bobbins
3)  it likes the tune but never learned the words to "It's too darned hot".
--SGS
Transformers will always make some noise due to slight deformation of the core by the magnetic field.  Do a Google search on "magnetostriction".
http://www.answers.com/topic/magnetostriction
I remember my shock when I came across an electrical engineering drawing for wood transformer wedges.  Some electronic stuff is low tech. Like Tie Wraps.
