Test method sheet- various uses
I'm looking for a generally written testing sheet that can be filed in manually or electronically for a multitude of testing. We run all types of spring tests, motor wear testing, corrosion testing, etc. It's my opportunity (task) to write a general testing sheet that can be used for as many types of testing as possible. Any good examples available on line or other?
thanks!!
thanks!!
RE: Test method sheet- various uses
perhaps what you need is a simple workbook/template with a sheet for each test type. the data (mainly input) can be stored into a database and retrieved when needed.
there are websites that can provide you direction and examples of what you may need.
if further help is needed, please be more descriptive in the needs.
good luck!
-pmover
All test sheets should be written around specific requirements and usually contain that specific information in the sheet itself.
A general purpose test sheet is by inference a sheet with lots of empty spaces.
TTFN
Test Sequence Name:__________
Test Date: __________________
Equipment Description: (Nameplate Info, plant application or customer number)___________
Test 1 Name _____ Test 1 Value _____ Test 1 Acceptance Criteria ______
Test 2 Name _____ Test 2 Value _____ Test 2 Acceptance Criteria ______
Test 3 Name _____ Test 3 Value _____ Test 3 Acceptance Criteria ______
Test 4 Name _____ Test 4 Value _____ Test 4 Acceptance Criteria ______
Test equipmenet used:_____________
Test equipment verified in calibration: Y/N ____
Results satisfactory? Y / N ____
If no, what additional action has been taken _________
Performer Signature _____
