Waste Removal From Railcars
I am working on a problem of getting municipal solid waste out of a railcar (65 tons lets say). My guess is these will be gondolla cars. I have come across a "tipper" in Roanoke and a "rotator" in Utah but these seem to be the only solutions I can find as I cross the web. Anyone have any other ideas on how to unload railcars of municipal solid waste in a quick and easy manner? Potentially, this could amount to thousands of railcars a year so "by hand" is not an option.
TIA, Randy
TIA, Randy
RE: Waste Removal From Railcars
Look at coal power plants, they unload on an order of 100 cars a day for a fair sized power plant, they also have to deal with freezing temperatures and sometimes irregular materials.
Hydrae
TIA, Randy
You will need a device that can invert the whole car, and you may need something that can shake it, too. The sort of gondolas that are likely to be used for waste will have had the side plates bellied out between the frames, from having metal scrap or ore dumped in them. The waste will wedge itself in the bellied out plates. In winter it will freeze, too. You'll need a shaker that's capable of destroying the car.
You'll probably still need a crew of sturdy lads with pikes and smoke wrenches.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Side dump has been done, sort of like a gondola with a side that falls open, and the body tilts to discharge the contents. No need to uncouple.
Mike Halloran
NOT speaking for
I think any modifications to the gondolas makes it immediately a dedicated train, less flexability to add capacity, lots of maintenance, and susceptability to damage to the various mechanisms. There are also major AAR issues in the modifications of old cars. I assume you would want old, cheap, gondolas, not building new from scratch.
coal and grain unit trains typically rotate the car to dump as noted above. With rotary coupler on one end of each car, the trains never uncouple for months or years. Fil on the go, dump on rotary dumper, and back to the mines. 'Lather, rinse, & repeat'.
The coal cars you may be more familar with that bottom dump get the product using the long wall method which does produce the uniform material that works well in bottom dump cars. Coal from the Rocky mountains is more irregular and the cars have a solid bottom and use a whole car tipping equipment for unloading. I saw advertsing for this equipment in electric power trade magazines some time ago.
Hydrae
To unload the cane they just pick up one of the bars with a grapple which lifts and traverses the bar. The cane is ejected out of the top and to one side of the truck.
Perhaps a variation on this theme would do you?
Lester Milton
Telford, Shropshire, UK
You will notice that all garbage is carried in Specialized Container on Flat Car(COFC) trains.
