Deflection Calculation for Round Plate?
I am trying to do a deflection calculation for a round plate that is supported around its circumference. Anyone know how to take into account the support around the circumference into a deflection calculation?
RE: Deflection Calculation for Round Plate?
There are over 50 formula and 100 configurations of round plate loading and boundary conditions published in "Roark's Formulas for Stress and Strain". The probability is high that your case could be found there.
http://www.efunda.com/home.cfm
A round plate, simply supported at the circumference has maximum bending stress at the outer edge and maximum deflection at the centre. Assuming a uniform round plate of constant thickness and again, assuming a uniform pressure distribution across the wetted membrane then this becomes:
y = [-qa^4(5+v)]/[64D(1+v)] for q=pressure, a=radius and D=plate constant
M = [qa^2(3+v)]/16 for v=Poisson's Ratio
The plate constant is calculated as D=Et^3/[12(1-v^2) where E=Young's Modulus and t=plate thickness.
Finally, the stress is found as S=6M/(t^2).
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
