Formula not taking
Formula not taking
Just learning V5 so bear with me.
I created a simple formula, say length =100mm. When I edit the dim in the sketch under Edit Formula the change doesn't take. It returns to the old dim w/o the f(x) next to it. Is this a setting issue.
Ross.
Ross.
RE: Formula not taking
Another question, I am from UG and we can change the value of the dim's on the fly. Is there a way in Catia. Now I am putting it in, locating click OK then double click dim to edit. Is that the only way?
Ross.
I am also a UG persone so I know your pain. In Catia you alwas have to add a step or a mousclick to do something easy.
If you are making user defiend perameter then you can chang it from the specification tree. under tools -> options -> infrastructure -> part infrastructure -> display and check peramiters. now you sould have somthing in you tree called peramiters and you can change the value their.
