High current wire to board connector
Hi all,
I'm into a high-power (5kW) DC/DC converter design. I need to find a way to properly bring all this current onto the power circuit PCB. The input side is ~200A@25V and the output is ~100A@50V.
Any idea about how I can connect the input and output wires on the PCB?
Alex
RE: High current wire to board connector
Generally you use solder type terminal blocks and jumper several of them together per leg.
Where are you going to get a PCB that can carry 200A?
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
w i d e   traces...   :)
In fact, there isn't a single trace that carry all the current. The current is carried in a bus bar and then splitted in 8 on the PCB.
