Can't get SendKey to work right
I have a structural analysis program (CADRE) that I'm trying to control with VB6 and the SendKey command. I have done this before with AutoCad and other programs with success, but can't get it to work consistently with CADRE. I open to a load file dialog box and press a "Remove" file command button in order to set up for the text string (CADRE has no quick key assignments.) Then I click on my VB program and press my "Run CADRE" button which puts the focus on the CADRE dialog box and sends the keyboard string. It works about 1 out of 10 times.
The subprogram is two lines..
AppActivate
SendKey
I have experimented with all combinations of wait in each command.
I have tried to clear the keyboard buffer by sending a nul string.
More Info...
I am using XP Home service pack 2 and VB 6.0.
CADRE says that their program is an upgrade to the dot Net framework.
I use a KVM switch but had the same problem on a stand alone PC.
I am not a professional programmer but have been programming BASIC for about 15 years starting with BASICA through to VB 5 and 6.
Any help would be appreciated.
-Mike
AppActivate
SendKey
More Info...
-Mike
RE: Can't get SendKey to work right
If anyone has ideas, your help would be much appreciated.
-Mike
