350 kW Diesel Generator
This is an old diesel generator. 4.16 kV, 350 kW, 80% Power factor. For setting the negative sequence overcurrent protection I need information on the negative sequence current capability of the generator. The manufacturer does not exist any longer. I would be greatful for some approximate data of a similar unit on the folloing questions:
Generator continuous current unbalance withstand capability, percent of rated current?
Generator negative-sequence current short-time withstand capability, seconds?
Thank you,
Thank you,
RE: 350 kW Diesel Generator
K = (I2)^2 * T
K is normally supplied by the manufacturer. Typical is 30 to 40.
Also see thread238-92588 and ANSI C50.13.
