Allowable vertical deflection of footbridge
Hello all.
I'm looking at the design of a footbridge. The form of the bridge is a steel through girder vierendeel truss.
I have been looking in BS 5400 for an indication of deflection limits under dead + imposed loads. There do not appear to be any such limits in BS 5400, but there is a statement that the deflection should not affect the servicability of the bridge, or affect the applied corrosion protection.
I wondered what type of limits other engineers employ on such structures? The deck is to be stiffened steel plate, and as such there are no brittle finishes.
VB
VB
RE: Allowable vertical deflection of footbridge
Here in New England, the major supplier of pedestrian bridges limits vertical deflection of the main trusses due to pedestrian live load to 1/400 of the span, unless specified otherwise. Other members such as floorbeams and stringers are limited to 1/360 of the span.
Dependent upon who will be using this bridge, general public or manufacter/construction workers, "structural aesthetics" will play an important role. For instance, if a 3/8" sag rod could support the whole bridge, place a 2" diameter pipe around the 3/8" sag rod.
Also keep an eye on vibration, a little extra dead load may be beneficial to dampen out foot traffice on a light structure.
I'll limit deflection to L/500 under live loads.
I also take on board the comments regarding vibration. Here in the UK the Design Manual for Roads and Bridges specifies a minimum natural frequency of 5 Hz for vibration in the vertical plane, and 1.5 Hz in the horizontal plane.
Thanks again !!
VB
