User input text
User input text
User input text
I want to use the acutal dimension by using <> but I want to have it display under the the first line.  It is </x> or something.  Does anyone know how to do this?
RE: User input text
never mind I got it.
RE: User input text
How do you do it? I've wondered if this was possible.
RE: User input text
<> \X
THE <> SAYS TO USE YOUR ORIGINAL DIMENSION AND THE \X MEANS TO GO TO THE NEXT ROW.
RE: User input text
If I use <> \X the dim moves up & if I use \X <>, the dim moves down. Thanks for the tip.
RE: User input text
You can also also type a msg before your dimension by
msg <> msg
then you can have custom text before and after your dimenstion.
