Linear vs non-linear intake/exhaust acoustics
I hear much about the benefits of linear acoustic simulation of intake/exhaust systems.  My own thoughts are that it's a waste of time given that all exhausts and most intakes are non-linear.  Any thoughts?
RE: Linear vs non-linear intake/exhaust acoustics
Linear acoustics refers to the form of the differential equations used - the equations are linearized to allow a closed-form solution.  In general, the linearized equations are adequate for most acoustics situations; we even used them for combustion stability analyses of rocket engines.  Until the oscilliatory component of pressure exceeds 10 to 20% of the mean pressure, the linearized equations are reasonably accurate.  As long as one is clear about what the limitations are, the linearized solution can be very useful.
Agree, but there is one non linearity which occurs often in automotove exhausts. Typically too small a downpipe is specified, and the flow in the downpipe becomes heavily turbulent (I'm tempted to say it is approaching M1, but doubt it) giving a chracteristic raspberry noise on full throttle. You can reduce its audibility by using a twin wall downpipe, which used to be cost prohibitive, but of course with Euro 4 etc it is much more common these days.
Cheers
Greg Locock
Greg:
Twin-wall pipes, often called "laminated" pipes,  are quite reasonable in price in North America,  and have been in OEM use for quite a number of years.  Here at least they're produced by simultaneously feeding two separate strips of steel into a tube mill, the inner tube strip being of course slightly narrower than the outer,  and welding the two together in a single common weld seam.  I've seen this done using the slower TIG welding process, and have heard of it being done with high-frequency welding as well.
This construction doesn't give much thermal benefit, not like air-gap pipes,  but is far better at reducing noise, since the friction between inner and outer layers creates a very "dead" pipe.
Since there's little if any increased fabricating cost,  and the inner and outer layers are typically spec'd at a much-reduced wall-thickness, there is very little increased cost compared to a homogeneous pipe, and certainly little cost compared to the NVH benefits.
I personally initiated the design and release of exhaust downpipes using this material for V8 and inline-4 Diesel engines in light trucks in the U.S. - for the F-word company - using tubing made by Arvin; they've since sold their tube mills to AK Tube, a division of AK (formerly Armco-Kawasaki) Steel.  By specifying a less-expensive material for the inner wall (w/o salt-corrosion resistance),  I was able to keep the final assembly price for a V8 'Y'-pipe to no more than a $0.50 increase over the conventional part (but this was 20 years ago).
 - R
