File location
File location
pro/e 2001, say you have a part/assy already open how do you find which directory / location model belongs to...you can use windows explorer, search the name of file and find its location. But any options on Pro/E to show its directory/location after the model is opened, excuse if silly...raj.
RE: File location
Click on Info, Session Info, Object list. Find this file and open it, it should tell you the directoy for each part open up...
I think there was post in this forum about this subject, have a search.
Tofflemire
RE: File location
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
RE: File location
You had mentioned "Find this file and open it", but ques is not finding the file, I ALREADY have a FILE OPENED, just want to find its location and nothing else.
Am I not following you peoperly!!!!!!!
-raj
RE: File location
Try this, Info, Model, pick top level. Also set the following config.pro setting info_output_mode to "both"
Hope this helps
Tofflemire
RE: File location
choose, screen, file, both
sets the default for how information is presented.
choose—brings up the info outputmenu where you choose whether to view the info on screen, write to a file, or both.
the other options set the default to one or both of these and does not prompt you with a menu.
this option applies only to the following info menu selections: names, model info, layer info, bomand audit trail. all the other info selections always present their outputs to the screen.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
RE: File location
I want to give it this way>>>>>
C:>>Folder name >>Folder name >> file name.asm
I chgd the config.pro settings too....any more suggestions......Thanks, Raj.
RE: File location
If display_full_object_path is set to yes
in config.pro
if you do a info from assy. it will give you the full path in the inf file
otherwise if it's set no... I don't think it shows up in the
inf file
ooops... thinking again
RE: File location
RE: File location
Cadcamguy is correct, I had that set just forgot about that setting, that was why I was getting the path to show...
Tofflemire
