Error 380 Invalid Property
Hi everybody,
when I am running my analysis, I am getting the following error message: "Error 380: Invalid Material property".
I've gone back and changed the joint at which the problem arose, and ran the analysis again, only to see the error message once more for a different joint.
I do not understand what the error means, or where it comes from. Is there a limit to the number of nodes or shell areas that can be put in a model? It always happens after the same amount of time after the start of the analysis.
Simon
Simon
