Trouble with a Shape I think.
I am haveing a problem with a shape ( I think)
I made a custom linetype that needed a shape to make the linetype. It is a line of condensation line that has a drop shape in it.
Other users are complaining about the need to cancel out of the 'Select shape file' when the dwg's are opened so I am trying to remove the linetype and shape from the files.
The problem I have found is that I can open the files in single drawing mode and the 'Select shape file' dialog box does not coem up. I then turn off the single drawing mode and open the same file it then shows the dialog box.
I did this without doing anything after opening the first file . It is lot listing that there are any shapes in this drawing.
Anyone got any comments on this????
