Largest available diameter in seamless construction
Is it possible to get seamless pipe and wrought fittings (elbows/tee's) up to 42" ? We normally only concede use of welded pipe/fittings in our tankage areas for raw and finished products where systems are rated to 150#. This area is not classified as sour service. Now our process designers have come up with a 42" overhead line that is to be used in our process area in a service where we have the risk of sour gas. Now i'm worried about the use of welded, non-NACE specified components in this new service. If i could get seamless in this size, then i wouldn't necessarily have to specify NACE would i ??
RE: Largest available diameter in seamless construction
Steve Jones
http://www.pdo.co.om/pdo/
