GM Material Equivalent
I have a drawing for Weld Nuts that specifies the material type as GMS218M. G.M. is the end user so I am assuming that the material is a GM specification. There were not hits at all on the internet for this item. Can anybody tell me what the SAE or ASTM equivalent would be for this material?
RE: GM Material Equivalent
http://www.global.ihs.com
Perhaps this is a clerical error with typing or writing or transcribing, etc.
Cory
I found GM218M which is a spec governing "Performance requirements for external acrylic ornamentation / second surface decorated"
Contact your buyer or your DRE.
regards,
Hydroformer
I checked with the requisitioner and the correct spec is GM6218M grade 340. We assume the 340 refers to HSLA material, but we would need to procure it in a Ø 1.25" bar. My initial material source stated that he has never seen 340 HSLA in a bar form of that size. Could he be mistaken, or is the engineer possibly specifying the wrong material?
Tom Klosowski
Delta Research Corp.
www.delrecorp.com
This is NOT the correct spec. for bar stock.
regards,
Hydroformer
Thanks for the help!
Tom Klosowski
www.delrecorp.com
