UG Parts List
UG Parts List
Simple question I'm hoping someone can answer.
With UG Parts Lists, what is the preferred method for callout numbers..meaning..do most let the program automatically assign a number or do you manually control the number yourself?
RE: UG Parts List
RE: UG Parts List
RE: UG Parts List
RE: UG Parts List
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: UG Parts List
RE: UG Parts List
RE: UG Parts List
due to the problems of maintaining the list after release too but I didn't know you could lock a list. How is this
done?
Thanks in advance....
RE: UG Parts List
Ben Loosli
Ingersoll-Rand
RE: UG Parts List
Mouse over columns and right click to menu w/lock option on it. I may try the callouts on the next job.
When initially building the parts list.... Can you sort on another field (say mat'l) and regenerate the callouts numbers so they flow properly again? ... 1,2,3,4 instead of
8,4,7,2 etc...
Thanks in advance Dave
RE: UG Parts List
good57morning@netzero.com
