evaporator pump on absorbtion machine
what can cause an evaporator moter to cut out on a steam absortion machine other than a motor overload
RE: evaporator pump on absorbtion machine
There may be a low level switch for the evaporator. It might be interlocked with vacuum level. A clear description may yield better suggestions.
