400 HZ Power Monitor
Does anyone know af a 115 VAC, 3 Phase power monitor that monitors loss of phase, phase imbalance etc. Thanks.
RE: 400 HZ Power Monitor
in a/c that do have 115V Ac power, there must be an LRU called BPCU for each bus powered by a separate circuit. This does all the power monitoring, including phase inbalance. It is generally located between the bus and its generator.
http://relays.tycoelectronics.com/hartman.asp
Jess
